fuel gauge wire???? dont have one on sending unit???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TIGHTWORK82 K5, Oct 17, 2002.
  1. TIGHTWORK82 K5
    TIGHTWORK82 K5 1/2 ton status
    Oct 21, 2001
    140
    orlando , florida
    I can not find a place to connect a wire on top of the fuel tank for fuel gauge. (82 k5) there is a pink wire going back there but nothing there to connect it to. guess I will have to drop the tank for a better look, just filled it too damn it. any help would be awesome. /forums/images/graemlins/1zhelp.gif
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    The pink wire has a rubber end on it much like a tiny spark plug boot. It goes on the steel nipple..see exploded view...
  3. TIGHTWORK82 K5
    Oct 21, 2001
    140
    orlando , florida
    ok, cool and that is a negative connection correct?
    the wire was hooked to the tag lights but they never worked. I found the right connection for them in the back got that hooked upthen I was thinking the pink lead was the fuel wire, it carried no voltage. I checked it to ground with and without the key on. I then put it to that nipple and gauge did nothing (it is all the way past full)
    I might try to run the wire dirrect. I traced it to the back of the fuse pannel. hell it may not be the right one! /forums/images/graemlins/confused.gif
  4. TIGHTWORK82 K5
    Oct 21, 2001
    140
    orlando , florida
    hey thanks for the pic by the way. good job!
    the black line is ground??
    pink fuel lead???
    I also found a ground back there. its not hooked up either
  5. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Yeah, the black wire is actually crimped into the sending unit and grounds to the frame.
    No prob on the pic, happy to give back to the CK5 community...
  6. dyeager535
    26,975
    The pink wire IS essentially direct, pegged full is an indication that there is no ground as I recall.
    Dorian
  7. TIGHTWORK82 K5
    Oct 21, 2001
    140
    orlando , florida
    hey thanks for the help got it working for the first time since i bought it. /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
