fuel gauge
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Mar 19, 2001.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    My fuel gauge is having problems. First of all, when i fill the tank up all the way, the gauge only goes 3/4 of the way. After alittle bit of driving, the gauge goes up to full. Slowly as the gas is used up, the gauge floats. Like i will look at it and there will be 3/4 a tank. Then next when i look at it, there will only be 1/4. Pleease help
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    There is a little thing on the sending unit that kindof buffers it so that it doesn't register as the gas slops around. A new sending unit is around 100 bucks. You might check all the wiring before you replace it. Mine did that and I found the insulation burnt off from the header. I rewired it and it's fine now.
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
