fuel gauge
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NOT4SHW, May 27, 2001.
  1. NOT4SHW
    NOT4SHW Guest
    Anyone ever had a problem with the factory fuel guage spinning like it's a helicopter blade? Any help would be appreciated.
    '79 K5,13 1/2" lift, 39.5 TSL's,15x12 Eagles,350,t-350,warn 8274,
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    No......but does it actually spin around by itself when the key is on? If so, you have a bad gauge. If it just spins when you move the hand with your finger that's normal.....it's made to spin all the way around.....free air movement or some such name. It uses one constant 12 volt coil to create a magnetic field. Then the other coil varies depending on the resistance of the sender.
    Michael[​IMG]
    <A target="_blank" HREF=http://www.jmartin.net/parker/goose.htm>http://www.jmartin.net/parker/goose.htm</A>
  3. DzrtRat67
    DzrtRat67 Registered Member
    May 26, 2001
    17
    A.J. , Arizona
    Mine does this too (77 K5)
    Have been told numerous times that this symptom is nearly always due to bad ground at the sending unit. Mine seems to be fine, I even made a small jumper to try and diagnose...still no luck. I'm convinced it's the sending unit. Good Luck.
  4. NOT4SHW
    NOT4SHW Guest
    Thanks for the tip. I've got the ground wire spliced at the gas tank and that makes pefect sense for being the problem, because it started acting up after forging about 4' of water, and it started working yesterday after I messed with the ground.
    Thanks!
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    mine started bouncing from e to full when going down the highway. no matter how much was in the tank. i fixed it by replacing the sending unit. if you got a body lift it is a bit easier. good luck...
    Grant
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
