Fuel Gauge
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WinnipegK5, Apr 8, 2003.
  1. WinnipegK5
    WinnipegK5 Registered Member
    Aug 27, 2001
    66
    Winnipeg, MB, CANADA
    My fuel gauge reads all over the place no logic behind readings. I have the tank out tonight to install a new hitch so I figure nows the time to find the problem. Any tips on testing to see whether it is the sending unit, wiring problem or the gauge??
    Mike
    Winnipeg, MB
    "That's in Western Canada where we support the men and women of the US Military" /forums/images/graemlins/usaflag.gif
  2. dyeager535
    26,982
    191
    Does it bounce around when moving (like its measuring fuel "slosh") or is the reading random even if the vehicle is just sitting?
  3. WinnipegK5
    Aug 27, 2001
    66
    I doesn't slosh around. But you might fill it up one time and it would read 1/2 then drive for a day and then it would read 3/4 .
    Mike
  4. dyeager535
    26,982
    191
    Hmm, could be a few things. Gauge, wire to gauge, ground from sending unit to body/frame, or sending unit itself. I'm sure there is a test for the sending unit, but no clue what it is, probably measure resistance as the float travels from the full position to the empty position.
  5. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    To test everything except the sending unit and unit ground:
    Take a 90 ohm resistor (from radio shack) and connect it to the lead that connects to the sending unit. Your gauge should read a steady full tank. Remove the resistor.
    Next take 2 90 ohm resistors in parallel (giving 45 ohm in the circuit) connected as before. Gauge should read 1/2 tank.
    Put lead straight to ground (0 ohms) gauge should read empty.
    With no restiance in the circuit (open circuit) it should peg well past full.
    If the gauge reads fine, then you either have a bad ground or the sending unit is shot.
    If I get the time I'll post a diagram.
    Hope this helps.
