fuel gauge
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dutterback, Jan 17, 2001.
  1. dutterback
    dutterback Registered Member
    Mar 12, 2000
    22
    Missouri
    could anyone tell me what the most likely cause for the fuel gauge on my 87' suddenly going way past full and refusing to work?
  2. dyeager535
    26,977
    I *think* that means the ground is bad for the sending unit. I was looking through my service manual last night, and I just skimmed the fuel gauge check procedure. Each problem associated (incorrect reading, over full, etc) had only one cause, but I think overfull is ground...someone else will probably know for sure.
    Dorian
    My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  3. bking
    bking 1/2 ton status
    Jan 4, 2001
    176
    Alaska /Here from Ireland in Dec 2000
    How much gas did you put in it?
    I know with my 85 when I put 50 bucks in it, it stays about half an inch past full for days, then drops like hell.!
    Might be a sticky float in the gas tank?
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    it is a ground problem also check the sending unit and make sure that the wire is pluged into the top off the sending unit they come off very easily also do a search on this topic to get more info
    s.smith 77blazer lookin 4 mud
  5. dutterback
    Mar 12, 2000
    22
    Missouri
    I checked the plug it is o.k. (this is really conveniant with a hole in the floor of your blazer) I have a plug with a purple and a black wire, and also one going to ground. they all appear o.k. could it be a ground at the gauge? thanks
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes someplace between the gage and the sending unit you have a broken conection is what it sounds like to me (i could be wrong) now the fun part tracing it out lol
  7. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Disconnect the pink with going to the tank and see what your gauge does? Then ground it and see if there is a change? If there isn't any difference between the two it sounds like the sending unit is bad,,,,,
    C'moe
    <font color=black>the blazer is "Back in Black"
  8. Sax Art
    Sax Art Registered Member
    Dec 12, 2000
    49
    Western, Wisconsin
    Mine does the same thing in my 1991 suburban.
    I can tap on the clear plastic gauge face, and make it go to where it should, so I pulled the dashboard apart, and I found that the back of the gauge plugs into a receptical inside the dash like an electrical plug in a house does. So the connection on mine is bad there. I don't know how to fix it, so if you figure it out, let us know!
