Fuel grade??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cryptobiotic, Jan 22, 2003.
  1. cryptobiotic
    cryptobiotic Registered Member
    Dec 31, 2002
    53
    Utah
    What is the best fuel grade to use with a GM Crate 350 motor??
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If you're talking about the base model crate, it runs great on regular old 87 octane. Runs nice on the 89 also, but 91 burns too slow for the low compression. </font color>
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Always start with the lowest rating the engine can take, if it detonates then go one step higher.
    The higher you go in rating the slower the burn, less energy.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Start with the lowest. Break your engine in on that. I run the lowest octane in my crate and it is fine. I have also noticed that since I moved from Arizona to Colorado there lowest octane here is 85 instead of 87 which I ran in AZ. So far so good, but I have to bump up the timing a little still to.
  5. wheelin_willy
    wheelin_willy Registered Member
    Jan 23, 2003
    24
    well the idea behind octane is detonation. higher compression engines need higher octane but higher octane in your stocker means you can advance your timing a tad more to squeeze more power
