Fuel Guage acting funny
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TxK5Blazer, Jul 26, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    My fuel guage was reading about 1/4 of a tank low all the time but now it started reading way past full and just pegs out there what might the problem be it is an 82 with the 5" fuel guage?
  2. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    Mine did the same.. it's a bad sending unit..
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    ive got duals... it did the same.. 1 at a time until both did it.. but im buyin another truck to fix my problem..>!!!!
  4. Dandwg
    Dandwg 1/2 ton status
    Feb 9, 2003
    190
    Turlock, California
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif lol
  5. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    Before you spend the money on a new sending unit (they are quite expensive) I suggest you take a look at the ground connection for the fuel tank. Mine did the same thing, and it turned out that I had a corroded ground strap.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    definitely check the ground wire when they peg past full like that 8 out of 10 times its the ground wire /forums/images/graemlins/shocked.gif /forums/images/graemlins/thumb.gif
  7. manyblazers
    manyblazers Registered Member
    Dec 13, 2002
    33
    toronto, Canada
    My 87 did the same thing. Turns out the cap that the sending unit goes through in the top of the tank had a crack in it. The whole sending unit would rock back and forth giving bad readings. Touch of weld fixed it. Take if off of the tank first though /forums/images/graemlins/grin.gif
  8. wa_jeeper
    wa_jeeper Registered Member
    Mar 3, 2003
    85
    Great Lakes, IL
    I third the ground idea. I had the same problem on mine. I traced the wires all the way from the tank up to the motor and right near the header my ground wire had burnt through. Fixed that and the gauge works great now... only problem is now I know just how quickly that big tank gets emptied... /forums/images/graemlins/crazy.gif /forums/images/graemlins/wink.gif
