Fuel Guage calibration??????
Discussion in 'The Garage' started by Thumper, Aug 7, 2004.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    My 85 has the stock sender/ wiring/ guage in it. It was a new tank like 6 yrs ago. Everything was working ducky until a week or so ago.
    The guage started acting up... one day it would be reading overfull, the next 1/2, the next 5/8ths, the next 3/8ths etc. It was all over the place. I replaced the wiring from the cab back under the truck, and added a tank ground wire, and things seemed to be better but not much. It kinda seemed to stabilize around 5/8ths of a tank and move with the truck... example how the tank drops a bit when you climb etc. It actually dropped a bit over the two days also so I thought all was well. Then I ran out of gas last Sunday, indicating half a tank. When I added my jerry can, and got to the gas station I put in 20.00 worth, and the guage moved up and read almost 3/4 tank. Over the last 4 days, I have driven the truck every day, and the guage has steadily dropped as normal towards the half mark. I added 40.00 worth of gas today (50 L) and it moved up to well overfull. It totally seems like either the sender or the guage has been changed to think that half is empty. Has anyone ran into this before? Is there anything I can do? Do you think the guage or the sender might be the one messed up? I suppose the next step would be to yank the dash, run the truck out of gas again, and twist the gas needle back to around empty. Any other options? Is it possible to adjust the calibration of the system?
    Mike
  2. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    I'll email you or PM you a fuel guage troubleshooting document I have. Any questions about it, shoot me a PM.
  3. jacked_86chevyk10
    jacked_86chevyk10 Registered Member
    Feb 4, 2004
    42
    SNELLVILLE, GA
  4. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    Can you also email me that document. Thanks
  5. alec78
    Aug 5, 2002
    358
    Washington
    Shooting it to you both... /forums/images/graemlins/thumb.gif
  6. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Have you had the dash apart recently? Had something similar once. It turned out to be the needle had gotten bumped and turned on the pin on the gauge itself. Went and filled it full and then set the needle to full and fixed.
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Could be a loose connection in the cluster; eiter the plug going into the cluster or the connection to the gauge itself. If the gauge moves correctly, but is not in the right position, you might be able to pull the needle off and glue it back on in the right position.
  8. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Could you PM me the troubleshooting document also please..i'm having the same problems with mine...
  9. Thumper
    1,582
    Alberta Canada
    Cool! Thanks!
    Hope it will help me out.
    Mike
  10. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
