fuel guage not working...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Feb 10, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    OK... I really hate not knowing how much fuel I have... it really sucks...
    I thought it was the guage itself... so i popped out the old guage... put a new one in...
    I set the guage... moved it with my finger... to full... i turned the truck to run.. the guage went to empty... so the guage is fine... I flipped the tank switch... did the same thing went to empty... Supposedly the floats are fine... anyone know about the wiring with dual tanks on these trucks... really need this to work...
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    On my 90, it has an electric fuel pump...don't know what year you have, but if my pumps loses its ground, the gauge will do wierd things, but the truck also won't start...I'm thinking a bad sending unit is the problem.
    90K5
  3. reddog64
    Nov 9, 2000
    3,325
    it's a 1978... mechanical pump...
  4. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    If the gausge goes to full when the tank is empty it is the ground, if goes to empty when the tank is full it is the power usually. The sending unit is basically a rehostat. If the rehostat gets "varnished" by the fuel it is not making contact with the pickup. It sounds like that is the problem if you have power to the gauge. You either need to replace the sender or get some electronic cleaner and take the sender apart and clean it real well, personaaly I would replace the sender.
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
    <a target="_blank" href=http://coloradok5.com/gallery/albun31?&page=1>BLAZER PICS</a>
  5. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I had a similar problem once. The headers had melted the insulation off the wire that went from the tanks to the guage and it was grounding out.
    <font color=green>Can't sleep...the clown will get me</font color=green>
    <a target="_blank" href=http://www.bluefox.tv/~lara>My Wonderful Site</a>
  6. Chevit
    Chevit 1/2 ton status
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    Mine works fine when it is dry out, but once it starts raining it jumps all over the place. I first thought it might be the float but that would not have anything to do with the rain so I am thinking it could be the connections on the top of the tank. What do you think?
    84 K5, Crate 350, 700r tranny, 3.73 rear, 32 11.50 15, Q-jet
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    GM fuel senders have a range of 0 to 90 ohms. 0 ohms in the circuit will cause the gauge to read empty, while 90 ohms will cause it to read full. So reading empty all the time implies that the wire between the gauge and the sender is grounded out somewhere along its path.
    If the gauge reads way past full all the time, then you're looking for an open somewhere in the circuit.
