fuel guage problem
Discussion in 'The Garage' started by roxby99, Jan 22, 2007.
  1. roxby99
    roxby99 Newbie
    Jan 22, 2007
    peoria il
    I have an 88 k-5 blazer and the fuel gauge is pointing way past full. Whats the fix.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    When the tank is full it does go a bit past the full mark, maybe about 1/4" past or so.
  3. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    Haha I like that answer for a fix :haha:
    but yeah mine does that too I wouldnt worry about it, but if it bothers you and you really want to fix it I have no idea how you would unless it didnt do it before. oh wait i know, you can draw another "F" farther past the oringinal full mark:D
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    or your fuel gauge may not be hooked up at all. Mine isn't and its way way past full
  5. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Oh is it STUCK on full?
  6. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Stuck on full = an open circuit
  7. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    So does anyone have an actual fix for a gauge stuck past full ?
  8. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Could be a bad ground wire at the tank, or a bad sender.
    John
  9. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    go to the tank and unplug the wire for the gauge, i believe it will stay past full, and ground it to the frame, and it should go to empty, then if it does, it has a bad sender.
