fuel guage reads past full all the time
Discussion in 'The Garage' started by R72K5, Mar 9, 2006.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    on the 77 with dual tanks the fuel guage reads past full all the time and nothing else, never moves
    sounds like the wire is disconnected/broken somewhere ?
    or ground it lost somewhere ?
    (open in the circuit)
    what should i check first?
    and how can i get the fuel system switched to the driver side if the system is not working
    is complete system all intact though
    thanks for anything
  2. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    wish mine read past full, well at least you never have to worry about running out of gas! haha sorry but i have no idea
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    First thing I would check for is a loose ground connection
  4. Propayne
    Propayne Registered Member
    Nov 27, 2005
    67
    San Angelo, TX
    i have the same problem, would ihave to take off the dash to look at the wires or can i just look above the fuse box?
  5. readymix
    May 30, 2004
    6,706
    26
    Either would work, at least for a start.
  6. dyeager535
    26,979
    Your best bet is to start at the tank IMO.
    Very common, and likely, that the connector(s) at the tank are broken or corroded beyond recognition. You can't hurt anything by removing the ground and cleaning it up, plus while there you can test that the sender is not at fault.
    Of course interior wiring can be messed up, PO's do all sorts of crazy stuff, however, the gauge uses the same connections everything else does on the cluster (except the single sender wire) so if everything else works, it's likely not in the cab that your problem exists.
    Good look identifying visually ID'ing single wires under the dash unless you've done it a few million times, it's a spaghetti nightmare. :)
  7. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    on my blazer i had a similar problem, and i ended up running a jumper wire with aligator clips from the tank ground, to the frame...was susposed to be on there just long enough to see if that fixed my problem, and it did fix it.....and well two and a half years later that jumper wire is still there..lol one of these days i'll get under there and fix it proper..
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Mine reads around empty all of the time.....:dunno: :D
  9. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    mine did the same thing when i did my engine swap. i had to redo some of the wiring and accidentally wired the gauge to 12+ rather than the sending unit. made the gauge read at about 3 o'clock.
  10. dyeager535
    26,979
    Last post in this thread might help. http://coloradok5.com/forums/showthread.php?t=69917&highlight=fuel+gauge
    To simplify matters, throw out the resistor parts, and replace 90 ohms with "connect to nothing, gauge should peg full" and replace 0 ohms with "connect to good ground, gauge should peg E".
    If it passes that test, then the gauge isn't the issue, nor is the wiring there to the gauge from the point you tested, ideally at the inline fuel gauge wire connector near the tank.
    Also, I believe in a *dual tank* setup, GM used two different methods for running the gauge wiring. I recall my dad telling me that his '74 dual tank setup switched the tank sending unit wire at the tank switch, and at some point I believe GM got smart and started switching them at the tank switching solenoid.
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    see this is where i am confused
    mine already reads empty- or just past it- all the time
    it is switched onto the right tank and is the only one that works currently
    so definitely means theres an open in the circuit right ?
    how should a 77 dual system be wired up ?
    anyone know the wire colors and where they should run ?
    i know theres that light tan/brown color wire thats supposed to run from the fuse panel to the tank(s) and always is tucked into the driver side step plate rocker crevice
    but other than that i dont know, even though i have dropped alot of these tanks in the past, but i never really paid attention to wiring
    hmm
    so at this point so far i figure that if the wiring looks ok- at the selector switch in the dash- then the problem is surely gonna be somewhere under the cab or in the rocker wiring crevice
    no ?
    this has to be one of the extreme top stock/factory problems with these truck, heh
    thanks!
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    oh and which is full and which is empty-
    90ohms
    zero ohms
    seems like zero ohms is full since when there is an open in the circuit it goes over to full or past it
    right?
    so if i take the sender unit wire off the unit- and put a resistor inline with the wire end and the chassis ground- then it should go to empty
    IMHO
    thanks :D
  13. readymix
    May 30, 2004
    6,706
    26
    0 Ohms = Empty
    90 Ohms = Full
    Short = 0 Ohms
    Open = Infinate Ohms
  14. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok so infinite resistance is what would cause the needle to go to full or past full
    keep thinking backwards :O
    thanks
  15. dyeager535
    26,979
    If the gauge reads right for one tank, it can be assumed that at least the gauge itself is good, and so is the wiring past wherever the two tank sender wires merge.
    My dads got a similar issue, one gauge doesn't read for squat, the other reads fine.
    Sorry can't help with the year splits for wiring, you might be able to dig up a few posts that have wiring diagrams in them, or dremu's brochure page?
  16. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    both tanks dead, needle never moves, its all dead, i hate dual tanks, always seems to be this problme with them, more likely than with single tank
    i found Aaron's wiring pages on slosh but nothing related to tank wiring at all, no where even close
    and it looks like everything there is just for K5's only anyways
    hmm
    i may just end up dropping a tank and runnign single wire and 3/8" line and eliminating all the dual tank BS, its all nothing but trouble
    thanks :D
  17. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    120 ohms resistance in the right tank and 93 in the left
    is what ive got
    the right tank is a brown wire and the left tank is a blue wire
    theres another brown wire under there in the same harness and it is cut off under there and goes to nothing, and so does a green wire
    then at the dash switch is a pink wire in the same harness, but it doesnt go under the truck
    i assume the pink wire goes to the fuel guage
    what is the second brown wire and the green wire for ?
    one is for the switch valve assembly which only has one wire spot
    why is there a second brown wire ?
    they all these wires run from RH side of truck where the valve assembly is and over to the driver side and meet up with the blue wire out of the LH tank and then run up the frame rail into the firewall straight to the dash switch
    very basic simple
    and i cannot get the needle to move, i even tried jumpering the pink wire with the brown wires and the blue wire,
    to no avail, was a little of a spark though between the pink and the brown or blue wire
    how can the switch valve assembly only need one wire to run it ??
    wierd ?
    ideas ?
    thnaks
  18. dyeager535
    26,979
    First off, if you ground ONLY the pink wire, does the gauge move?
  19. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    nope the pink is hot as heck
    i grounded it and it blew the fuse
    apparently none of the wires at the dash switch go to the guage
    because all the wires thaty comes off the switch- other than the pink- go straight through the firewall and to the tanks/unit stuff
    what the hell ?
    oh and the browns are actually tan, one is striped and the other is solid and it is connected to the RH tank sender
    the striped one is cut off at the unit under there
    and so is the green one
    which plugs to the unit and whats the other for ?
    i assume the green goes to the unit and gets switched from hot to not hot
    hot coming from the pink wire at the dash switch
    i took another fuel guage and i connect one side to the pink wire and the other side to the blue wire and it pegs real quick over to full or hot- i forget which
    and i connect the solid brown wire to where i had the blue wire and it pegs again
    i know that hot is at the guage all the time with the key on, so i know im doing it right
    i dont know what the deal is and why theres no wire from the dash switch to the guage ??
    wth ?
    thanks
  20. dyeager535
    26,979
    Well, then we need to figure out which wires come from the tanks (sending unit wires) and where they go, so you can test that the gauge isn't an issue.
    NOW I think I understand what you were saying before...the tank switcher isn't working, and your fuel gauge works for neither as well. Correct?
