Fuel Indicator
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 19Jimmy87, May 9, 2002.
  1. 19Jimmy87
    19Jimmy87 Registered Member
    May 9, 2002
    65
    Kalamazoo, Michigan
    I just bought a 1987 Jimmy Sierra Classic. It is in real good shape. One of the only problems that it has is that the fuel indicator doesn't work. How do I go about fixing it? Who has the parts? Any help would be great.
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Check the ground at the tank. Or the sender wire at the tank. Sometimes they can come off. It could be a bad sender, but I dont think so. The guage usually doesnt go bad as long as it has not been messed with.
    John
  3. 19Jimmy87
    May 9, 2002
    65
    Kalamazoo, Michigan
    I will check everything. Thanks for the reply. If it is a sender or something, what would the parts run me?
