Fuel Injected 427
Discussion in 'The Garage' started by blazer_87, Feb 6, 2003.
  1. blazer_87
    blazer_87 Registered Member
    Oct 1, 2001
    72
    Section, Alabama
    I have an 87 K5 TBI. I am installing a 427 Tall Deck Engine. Does anyone know how or have any suggestions on how to keep the TBI? I need to either reprogram my computer to run richer or ............. open for suggestions. Thanks
    /forums/images/graemlins/k5.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Might have to have a chip burned for your application. I think its very possible.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The first couple of years of TBI 454 used a Q-jet intake with a water-heated adapter to mount the TBI unit. Either find this adapter, or I believe you can get manifold spacers to run a stock (short-deck) TBI intake.
    There may even be a factory tall-deck TBI intake used on the bigger trucks - dunno for sure.
    The TBI and harness on the 350 should be enough to at least make it run. Worry about the larger TBI and custom ECM later.
  4. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    How are you building the Tall Deck? Are you keeping the stock TD pistons w/ the extra ring or swapping to a standard style 454 piston w/ different rods?
    I have heard nothing but bad things about the intake spacers for the tall deck motors... from what I understand you are way better off to get the aftermarked intake for the TD application.
  5. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I know GM trucks had FI on TOP KICKS{think thats right}.Hope it helps. /forums/images/graemlins/thumb.gif
  6. blazer_87
    Oct 1, 2001
    72
    Section, Alabama
    I am going to take the block and get the .400 machined off and make it regular deck height.
  7. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Wow, thats alot of material to take off! What is the advantage to doing this instead of just starting w/ a standard 454 block, or is there one?
  8. blazer_87
    Oct 1, 2001
    72
    Section, Alabama
    The advantage is that I only paid $200 for a running 427. I dont think I could fine anything cheaper. After reading some more, I think I will keep the tall deck and stroke it. The main thing is getting the TBI working.
  9. u2slow
    May 9, 2001
    2,217
    BC Canada
    Probably a steel crank in that sucker too /forums/images/graemlins/rolleyes.gif
    ( /forums/images/graemlins/thumb.gif )
  10. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    I think when you finish milling .400 off the top of the block you'll be a little surprised. /forums/images/graemlins/shocked.gif If my sources at a local machine shop are correct, you'll have exposed the water jackets. /forums/images/graemlins/blush.gif OR very nearly so.
  11. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I've gotta agree with Sparky. If you mill .400" from the top of the deck, you'll have a junk block. If the 427 runs, then leave it alone, or fork out the $$$ for more expensive and limited parts for tall deck BB's.
  12. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Don't even think about milling down that engine's deck. I'll buy it from ya at that rate.
    the 427 td is a great engine when it's stroked. Lots of torque.
