fuel injection/intake question
Discussion in 'The Garage' started by jp0863, Jul 12, 2006.
  1. jp0863
    jp0863 1/2 ton status Premium Member
    Aug 15, 2004
    566
    clovis, ca
    i will be buying an 80 sub with a 400 and a bad carb, then buying an 88 with a good fuel injection and a dead motor. is it possible to install the fuel injection on the 400 to make a good running fuel injected 400?
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Yes but you will need to modify the intake manifold for the different bolt angle on the 4 center most intake bolts, then you will also need to have a chip burnt for the engine size and such. 400 needs more fuel and different timing curve than a 350.
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I agree with this, but you'll probably also have to raise the fuel pressure using an adjustable fuel pressure regulator.
    This is an easy conversion, but could take a little time with all the fine tuning.
  4. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    you can just use a TBI to spreadbore adapter to mount the TBI unit on your carb intake.....the carb ones flow better anyway. A chip will definitely need to be burnt though, a step to the 454 TBI may be a good idea too.
  5. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I have the spreadbore/TBI adapter if anyone is interested in it.
  6. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    awww.....geez....I have one for sale too.... Should have mentioned that!
  7. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I had a TBI 406 in my old truck, and did nada to the fuel or computer. It ran like a raped ape, gobs of torque, and no check engine light. I'm sure it would have run alot better if I did some of those mods. You can either swap the heads for the TBI heads, or enlarge the center two holes, the TBI are at a different angle than the older style. But they will work, seen it done.
