Fuel injection on a crate
Discussion in 'The Garage' started by seschev3, Nov 24, 2005.
  1. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    Anyone have any experience with fuel injection on a 350ho 330hp gm crate motor. Truck avenger has a cracked flange and I am tired of this carb that does not like a perfect tune. Fuelie in the future for me. Thanks.
  2. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    What's the specs on the cam. It could be a good candidate for a tpi swap.
    "TPI, the best truck motor GM never installed in a truck!"
  3. seschev3
    Jan 19, 2005
    308
    clayton, ca
    Thinking about changing the cam to get some better low end. My concern is more with a fuel injection system that can handle the 350 hp and 400 ft lbs. And a system that will work with vortec heads if a manifold change is necessary.
  4. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I'm still trying to decide on what kind of FI to go with. I've pretty much narrowed it down to the holley commander tbi or the edelbrock pro-flo... the pro-flo seems to be the better system for my needs but at $2000... :eek1: I have found a lot of good info about both systems by searching, I still can't make up my mind. More input from everyone who has either of these F.I. setups! Thanks everyone.
  5. oldtoyboyd
    oldtoyboyd 1/2 ton status
    Nov 12, 2003
    904
    3
    Leesburg, MS
    fuel injection
    There is a company called megasquirt that makes a stand alone fuel injection and ignition controller that will work with any engine. The system is under 500 and you use factory equipment with it to make it work.
  6. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    The megasquirt is an option but you'll still need a bigger tbi unit and a better manifold.
    I went with the holley 670 cfm tbi(bigger than a stock 454 tbi), projection 2 inch manifold(yes they sell vortech 2" manifolds) , bigger fuel pump, and a prominator for my 355. All that brand new costed me around 700 bucks and i can modify my fuel injection any way i want save different fuel maps and switch from one fuel map to the other with the flip of a switch... for example i can burn a smog fuel map(lean it out), a gas mileage map, etc., and switch from one to another with the turn of a switch.
    This setup will support over 350 hp and tq max is probably up around 450 ft lbs. This is a good way to go if you want to be able to customize your FI but it takes alot of reading and you'll need a labtop.
    Tpi is not my specialty but from what i hear the max power numbers are close to the tbi.
