fuel injection prob.
Discussion in 'The Garage' started by blazinjimmy, Apr 13, 2006.
  1. blazinjimmy
    blazinjimmy Registered Member
    Aug 28, 2003
    53
    I bought a 1990 full size jimmy....parts truck. Seems you have to prime the motor to start it..even then it wont stay running. Its a 305. I know nothing about fuel injection.......so any help appreciated.
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Check engine light on? Is the ECM tossing out any trouble codes?
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    uhh its not getting fuel.... fuel pump pumping? fuel filter clogged? fuel pump relay even there?
  4. chevyk2500hd
    chevyk2500hd 1/2 ton status
    Nov 24, 2005
    192
    Lafayette, Indiana
    It shouldn't be a 305 i think you meant 350. Also when you crank it over is there any fuel comming out the injectors. Maybe they are clogged if it has been sitting for a long time. Also something else clogging fuel supply may be causing low fuel pressure.
  5. blazinjimmy
    Aug 28, 2003
    53
    Sled Dog....Uuuhh......I figured it's not gettin fuel. The guy drove it over...so it does run. I put new filter on and the pump is pumping. [like I said..not familiar with fuel inj., so I'm assuming the prob. is at the injectors-it has been siting for some time]
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    are they spraying? take the air filter and housing off. You will be able to see the injectors, have someone crank it, you will see the injectors spray fuel. Or you should see them do so.
  7. blazinjimmy
    Aug 28, 2003
    53
    Thanks for all the info.....here's where I'm at; pump is working, new filter...and there is no spray at the injectors. [truck was running prior]
  8. Dr. Morgenstern
    Dr. Morgenstern Registered Member
    Apr 12, 2006
    92
    Tecumseh, Ontario (across from Detroit, Mi)
    Filter in the correct direction?
  9. chiggly626
    chiggly626 Newbie
    Jan 30, 2005
    3
    socal
    One other thing to check is the little module in the distibutor that tells the injectors to fire. Mine went out in my 92 and I would have swore the fuel pump was bad.
