Fuel Injection Q...
Discussion in 'The Garage' started by 84gmcjimmy, May 14, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Hey, I was wondering if you had a choice between a carb, like the Q-jet, or Fuel injection, what would you get? I am asking because I am building an engine eventually and want to get a list of parts to get. And what are the advantages/disadvantages of FI. State if you like it or dislike it. Thanks
    /forums/images/graemlins/thumb.gif
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Fuel injection all the way. I really like the GM TBI system. Pretty simple to retrofit in to an older truck and also it is easy to work on. Now if you are planning a pretty hot engine then you will need aftermarket fuel injection or possibly a TPI will work. For anything older like muscle cars or street rods I prefer carbs but in a 4x4 or daily driver FI is nice.
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Neither....get a diesel, mechanical injection is bliss...
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    /forums/images/graemlins/rolleyes.gif I don't want a diesel though /forums/images/graemlins/histerical.gif
    It will be for lots of mud and some rockcrawling...
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    For a motor that isn't crazy I would say a GM TPI setup would work very well. For a crazy high HP motor than I would look into some of the aftermarket EFI systems that are available. The good ones run from $2K and up though. The simplest thing for a hi HP motor would be a holley or demon carb. Not good for slopes but fine for a mudding rig... I wouldn't touch TBI on a motor that is built, IMHO they just can't supply a high HP big block(thats what you said you wanted to build, I remember /forums/images/graemlins/wink.gif) the stock GM version of course.
  6. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i wanna put that holley 2d projection on my truck, looks like would be the perfect setup for my truck.
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I heard that kit is junk. /forums/images/graemlins/dunno.gif
  8. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    I like the simple TBI set up. It's stone reliable,consistent in severe angles unlike carbs. But you are unlikely to get a lot of HP with it. I don't know your target HP/Torque goals, but if it's much over 310 HP (I think /forums/images/graemlins/thinking.gif) you'll want something like the Edelbrock multi port FI set up. FI is most valuable to me when my truck is unlevel. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif Bern. "All that is neccessary for the triumph of evil is that good men do nothing" Edmund Burke /forums/images/graemlins/burb.gif 87 Burb 350TBI/NP205/D60/14BFF/powerlock-Detroit/4.56s/39.5 TSLs.
  9. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    I like mine. [​IMG]
    MMMM...Vortec....Smoooottthh....torquey...readily available...I'll post my write up someday...I keep saying that but I really will someday.... /forums/images/graemlins/deal.gif
  10. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    383, Vortec heads, MPFI /forums/images/graemlins/grin.gif
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    rjf, I don't know if you read my recent post (can't remember the name) but the plan for the blazer is going to be big HP mudder, that also can rock crawl. So it has to handle steep slopes, and steep terrain period. So would fuel injection be good for that? What company would you suggest? Thanks /forums/images/graemlins/thumb.gif
  12. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    FI would definantly be the best for non level terrain. It runs at all angles unlike carbs. I wouldn't be afraid of a big Q-jet though, I have climbed some really steep hills before and had minimal flooding problems.
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay the desicion remains untold... I will keep thinking about it, thanks /forums/images/graemlins/thumb.gif
  14. G.M.H
    G.M.H Registered Member
    Oct 6, 2002
    78
    wpg. mb canada
    If you want big horsepower, then spend the money once, and get an aftermarket setup.Which ones are good? I don't know.The worst thing when trying to climb a long slippery rock with steep drops on either side,is to have your rig sputter and stall.Try backing down with no p/s or p/b.Or keep your foot on the brakes till someone can hook a winch on you.FI is the only way to go for rockcrawling.I am currently adapting a TBI to mine.
  15. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you are building a high HP engine. Look into a Holley Commander MPFI system. They are adjustable to your engine have a wide choice of injectors to choose from. You need a laptop to program it. I would pick the Holley Commander over the Stealth Ram systen because the Commander builds torque lower in the power band. The Stealth system is more top end power.
    The Edelbrock Pro Flow systems are very good also but they are limited on how much HP they will build.(400 HP?) They come with the chips/modules you need and you dont need a Laptop to program them. But they do have a programable one in the works that should be out soon. That should make the system build more HP.
