Fuel Injection Scavenging
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chosen(1), Jul 16, 2003.
  1. chosen(1)
    chosen(1) 1/2 ton status
    Nov 19, 2002
    206
    Michigan
    I am more-than-likely going to be scavenging the fuel injection off my future father-in-law's '87 'burb. What I need help with is making a good list of all the parts I need to get. The truck is a 6 hr. drive from me, so I don't want to forget anything.
    I know I need to get:
    intake (TB injectors etc. etc.)
    as much harness as possible
    computer
    fuel sender/pick-up/pump
    I know there is other stuff. Please add whatever I will or might need to make this as painless as possible.
  2. dyeager535
    26,975
    No, you need to get ALL of the injection harness. You need to pull the dash out, and pull the entire fuse panel. If you cut stuff off, you'll have to try and remember where it goes.
    Get the tank, save yourself time. The baffle may be broken, but you've got to pull the tank to get the sender and fuel lines out anyway. Yes, you need to get the fuel lines, so get a set of tubing wrenches. Don't half ass it now, or you will spend a lot more money and time trying to fix the problems later on.
    Anything you mess up now means you'll PAY to fix later. Besides, *I'll* have no sympathy if you come back asking for a wiring diagram if you try and take the easy way out and cut parts of the harness. /forums/images/graemlins/grin.gif
  3. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    For the novice removing the entire harness is the way to go...but you can cut out just the efi portion and modify the harness...
    DW
