fuel injection...yes I serched
Discussion in 'The Garage' started by supersize75, Jul 30, 2003.
  1. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    Well seeems every one in AZ is has fuel injection except me /forums/images/graemlins/confused.gif
    The confusion starts with my motor, its a 396bb.
    So will a 454 set up work? Even if it does while serching some people say that I have to replace the cam, others say no, this gets confusing. None of the other post mention a 396 too /forums/images/graemlins/frown.gif
    Can I use a electric fuel pump instead of the sending unit inside of a tank? Or is there a reason more people dont do this? I feel this would be more accesable than one located in a tank under my body. /forums/images/graemlins/thinking.gif
    Also after talkin to a few people I feel that Holly's set up isn't for me because of the whole computer involement, so what other companies are out there?
    If you feel this was a waste of bandwith dont respond, I just was had nothing else to ponder at 2 in the morning other than this. /forums/images/graemlins/grin.gif
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    any BBC system can work. fuel curve would need to be worked on.
    external fuel pumps are better, IMVHO, cuz when (not if) the pump goes out, it is easier to replace.
    Holley systems can work well, but seem to take more tuning time. if you get a screaming deal on one, they are still good enuff to run.
  3. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    A BBC TBI would work fine. The cam may or may not work depending on how radical it is (you need a certain anount of vacuum to run a TBI system). External fuel pumps work fine, they are generally more expensive than an in-tank pump though. I recommend staying with the factory system for everything possible, cheaper and spares available in more places. BBC TBI systems are not cheap or easy to find in my opinion. You have to be patient and persistent. I think part of the availability problem is that a lot of people take the 454 TBI unit and put it on there 350's for performance gains.
