fuel injection....
Discussion in 'The Garage' started by bryguy00b, Jan 21, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i might be goingto look at a 88 k5..and since its an 88...its got fuel injection..TBI im ganna say!??...the guy says its got a new tranny..but has not ban ran in quite a while. asked him about the body...says its pretty much solid but for the tail gate...and i happen to have a rust free shell...(but ill have to check this all out for my self of course..being in this area!!) but anyway....what kind of problems could come from a fuel injected truck not being ran in a while??
  2. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    the tbi is just about bulet prof and will have only minor problems like if the bat is dead the ecm will have to relearn how to run so the engine may not run well for a few minuets. I would be more concerbed about the new auto trans and its seals drying up or the engine rusting. but all these thing take along time[6 mounths or better] to happen.
  3. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    If the gas is over 6 months old it should be replaced and the lines flushed. Not much else except maybe cobwebs in the distributor and rats eating on the plug wires.
  4. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Bought my 88 new.Only prob so far was throttle body gasket leaking caused high idle after buot 200,000 miles.Run good injector cleaner in couple tanks of gas.Over 450,000 miles now,still going strong.Normal maint and timing gear assem at bout 300,000 only repairs.GOT A GOOD ONE !!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    true. The extra air is also leaning out your A/F ratio. I also learned about that. the 3 bolts are also supposed to be torqued to a wimpy 13 foot pounds on the throttle body.
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The TBI is a good system. You most likely wont have to even worry about it.
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    coo lthanx guys..ill let you know what comes up if i look at it.. /forums/images/graemlins/thumb.gif
