Fuel Injection
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by njonl, Oct 3, 2003.
  1. njonl
    njonl 1/2 ton status
    Jun 30, 2003
    128
    Northern CA
    Hi all,
    I own an '85 Blazer and the motor is tired. I just bought another car for a daily driver for a while. I figured I might as well park the Blazer and do a motor swap. I want to do a fuel injected smog legal motor. I live in CA so smog is important. My question is... Where do I start with this whole fuel injection process ? I am trying to stick to a budget if at all possible. What parts do I need to look for ? I am guessing this is a TBI system ? Any and all information is greatly appreciated. Thanks,
    Nick
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Start with a donor rig that has the engine, computer, and harness that you want.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You might have a tough time going FI in Calif. Most all aftermarket FI systems carry the disclaimer "May Not legal in Calif". You should do some research before you do the swap.
    I would talk to these guys:http://www.turbocity.com
    They are a california based conpany and have lots of experience with FI in calif.Im sure they can help you build one that will pass smog. They make very good reliable bolt on TBI FI kits based on the stock GM system.
  4. dyeager535
    26,980
    In CA, I would most definitely look for a donor TBI truck or a TPI car.
    TBI truck because you know everything will bolt right on, since the truck is already down, you could rewire it and have no problems.
    TPI because it rocks. Not as simple or "easy", but more rewarding in the end. Actually probably easier to come by a complete TPI unit than an '87-91 TBI truck setup.
    The only laws that you need to adhere to so it is legal, is that the engine needs to have been available in that vehicle (5.7 or 5 liter, no problem) and all the emissions stuff needs transferred. Also not really a problem, since EVAP,AIR, etc., is all the same idea/bolt on to a truck.
