fuel leak on 6.5 TD
Discussion in '1982-Present GM Diesel' started by stoney126, Jun 29, 2006.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    hey all, noticed I was leasking fuel. I believe i pinpointed the location. Looking from the passenger side towards the rear of intake manifold I could see something dripping. One of the lines leads to there. Anyway How do i render this problem? dont know much about this engine.
    Fuel was dripping off the starter and bellhousing. I followed the lines and they were mostly dry considering how much fuel was leaking ( a drop a second) The only thing I can think of Is the leak on the manifold. Thanks for any help
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    The fuel filter is back there. There is a short rubber piece to the filter housing from a metal line from the lift pump. There is a rubber line from the fuel filter housing foward to the Injection pump (runs underneath the intake manifold). Could also be your filter cap or it's vent valve.
