Fuel Leak?
Discussion in 'The Garage' started by BurbLover, Sep 10, 2006.
  1. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I have a 96 F350 PSD. It appears that there is a pinhole leak at the bottom passenger side of the fuel filter assembly.
    Is this a sign that something else has gone?
    Do I need a new fuel pump? Fuel filter assembly?
    This is the first diesel I've worked on, so unsure. Need to get this fixed today so I can get to work tomorrow. TIA!!!
  2. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Here are some photos of what I found. Appears to be a hole from the bottom of the fuel filter assembly.
    One is a not so focused close-up. The other is a clear shot. You can see the hole directly below the water drain vole outlet (black thing).
    Looks like I need top call the dealer tomorrow :(
  3. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    JB weld it and off to work you go. Order a new one latter when you have time and budget it. :D
  4. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    I was very hesitant to use JB weld. The guys at both auto parts places said to us it. I figure I'll check the cost & availability of a new one first. I already have a way to work this week, is that's not an issue.
  5. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    I found the part # I need. It's Ford # F6TZ-9155-A. The dealer wants a fortune Anybody know where I can get one cheaper? I can't find one online.
  6. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
  7. chalet2506
    chalet2506 1/2 ton status Premium Member
    May 9, 2006
    4,931
    Skeddadlin
    they make a fastweld specifically for fuel tank use. I used it and a quarter to patch a hole in an alluminum tank on one of our trucks, no problems yet. Can't remember what the name of it was though.
  8. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    After about 3 hrs of research over the past two days, I dicovered that this can only be purchased via the dealer. And, since I plan on keeping the truck for awhile (or give to brother), I didn't want to chance a used one or trying to JB Weld it. So, I ponied up the $500 (including tax) and bought new. Now for that price, it comes with a new filter, fuel regulater, temp sensor and a few other msic items that I don't know what they do. Now, to put it back together :)
    EDIT: I wanted to add that I spoke with the head of a diesel shop in town. He emntioned the main causes of this are not emptying the water seperator valve often enough and having sand/rocks/etc in the bowl. Since there is no pre filter to the unot from the tank, the sand/rocks tend to swirl around & wear at the interior of the assembly.
  9. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    crazy fords
  10. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    friggin fords...
    Being the cheap SOB I am,I'd have just put a sheet metal screw in it ,with an O ring under its head!..:whistle:
    What!!??..I drove a truck with a pinholed gas tank that way for 3 years before I finally had to replace the tank...:wink1:
  11. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    I debated about either putting a screw in the hole or trying JB Weld. The hole was actually very close to the rounded edge, which would have made the screw trick a bit difficult. I decided on new for a few reasons:
    1 - This is my daily driver. It needs to be dependable.
    2 - This is my only vehicle. See #1.
    3 - By the end of the year, I will be moving using this truck. I'll be pulling 7000 lb fully loaded enclosed trailer for this move & I can't afford to break down in the middle on nowhere. See #1.
    4 - I didn't want to have to take it apart again :doah:
    Lucky for me my credit card just went up last month:bow:
