Fuel Line crimp?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JohnnyFresno, Jul 19, 2002.
  1. JohnnyFresno
    JohnnyFresno 1/2 ton status
    Mar 24, 2002
    194
    Clovis, CA
    I notcied the other day that my fuel line going into the carb is crimped right before the filter and the nut to the first nut to the filter is stripped. I was wondering if the crimpage is normal, and where can I find a replacement line from pump to carb?
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Can you take a pic of it?
  3. dyeager535
    26,975
    Can probably get the line from GM still, and the crimp is not normal, usually its from someone trying to loosen the nut, but the line being frozen to the nut, and so the line twists as the nut is being loosened.
    In the future, to somewhat prevent that, the line can be disconnected from the fuel pump first, so the nut on the carb end can be loosened and the line can move a bit, then usually you can break the bond of the nut to the fuel line, without twisting the line.
    Use tubing wrenches as well, to prevent stripped out flats on nuts.
