Fuel Line Flare Tool for TBI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tys, Apr 5, 2003.
  1. tys
    tys Registered Member
    Mar 17, 2002
    35
    Endicott, NY
    Hey guys...I'm putting a TBI into a non-TBI vehicle. The TBI came with the hard to braided stainless fuel lines, which I'd like to use. I tried connecting my existing hard line to the stainless line, but it wouldn't work. Looks like it requires a special flared end w/o-ring (similar to the end which goes into the TBI). Anyone know what I'm talking about?
    Chris
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The easiest solution may be to get the last few inches of hard line from a donor truck, then splice that into the existing hard line on your truck so that the flex line can be hooked up. /forums/images/graemlins/cool.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    and TBI system in stock form is around 9-13 PSI so you can rubber hose and hose clamp the system without worry.
    good luck
  4. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Or the other option is what i did twice now...donor fuel lines froma 87 to 91 K5...yes...that means the Chalet is allmost done... /forums/images/graemlins/thumb.gif
    DW /forums/images/graemlins/usaflag.gif
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">You can buy 12" fuel line repair kits complete with o-ring flared end, male fitting and a coupler for about $12 a peice at your local Napa. This is how I hooked my home made lines to my TPI fuel rails
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I pieced mine using ends from a donor truck and common brake/fuel lines from the parts house.
  7. tys
    Mar 17, 2002
    35
    Endicott, NY
    Thanks. I will stop over there in the next couple days to check them out. Need a fuel pump relay anyways!
    Chris
