Fuel Line help
Discussion in 'The Garage' started by jaredmajor, Jan 26, 2006.
  1. jaredmajor
    jaredmajor Registered Member
    Mar 2, 2005
    96
    Anchorage, AK
    i have two 16 gallon tanks. I think the second one was added on by the previous owner, scary. He only has one fuel line from tank #2 to #1, then from #1 to the fuel pump is one line. I have a second line from #1 that goes up to the fuel pump, but isn't connected, what is this, is it a return line? Is it a vapor line? Can i plug it? that just looks like a way for water to get into my fuel.
  2. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    you should have a fuel return line and does the second line have a second pump cause if it dosnt it needs one. the best way do work this is to have each tank have its own pump and lines and put a switch om them to switch back and forth
  3. jaredmajor
    Mar 2, 2005
    96
    Anchorage, AK
    It's a mechanical fuel pump though, does that make a difference?
