Fuel Line Plumbing Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LoggieStyle, Apr 11, 2003.
  1. LoggieStyle
    LoggieStyle Registered Member
    Jul 10, 2002
    78
    Tujunga, CA
    I'm converting my blazer to a 99 454 vortec setup, I just got a new tank and sending unit so I am ready to do the plumbing. I know I will have to add a return line for the FI but for the others can I use the same lines that went to the old 350 or do I need high pressure lines or something?
    If anybody have any other tips or things I should keep in mind while doing this I would appreciate it. This is my first engine swap.
    Thanks,
    Logan
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    What are you using for a fuel pump? in tank pump from the vortec set-up? I would use as many parts as possible from the vehicle the engine came out of, as the '75 fuel system was totally different, the vortec uses higher pressure. If you can't get the original lines, get a good look at a similar equipped vehicle and make your system like it, use as much steel line as possible, use double flare connections for any required splices. If you do have to use rubber hose get the correct hi-pressure type hose designed for the newer FI systems.
  3. LoggieStyle
    Jul 10, 2002
    78
    Tujunga, CA
    It's a new high-pressure pump for the vortec engine. The engine came out of a 99 suburban but I never got a a look at the fuel lines. I'll follow your other advice for now and try to get a look under someones suburban over the weekend.
    Thanks,
    Logan
  4. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    If your existing fuel line is 3/8" you can use it just fine for the Vortec setup. If it's 5/16", you can use it for your return line and add a new feed line that is 3/8". Typically, you will need to modify the sending unit to provide for a return line by drilling the flange and brazing a tube in for the return.
  5. LoggieStyle
    Jul 10, 2002
    78
    Tujunga, CA
    Thanks for the help, appreciate it.
    Logan
