Fuel line question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Summer95, Jan 17, 2003.
  1. Summer95
    Summer95 Registered Member
    Nov 16, 2001
    6
    Houston, TX
    Does anyone know if the 83 full size blazer fuel line is a hose or is it steel?
  2. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    if its anthing like an 85 it will be both
  3. dyeager535
    26,977
    Steel EXCEPT where there might be movement.
    All along the frame its steel, from tank to frame its rubber, from frame to fuel pump its rubber, and from fuel pump to carb it's steel. Probably less than 12" of rubber on the main fuel line.
  4. Summer95
    Nov 16, 2001
    6
    Houston, TX
    Thanks, that's what I thought. Any ideas where I can order a new one that comes from the pump to the carb? I called the dealership and they didn't have one listed.
  5. dyeager535
    26,977
    Sounds to me like they are A)idiots or B) lazy.
    Pretty sure those are still available (they are definitely in the old parts books) but you can try www.lmctruck.com or www.gmpartsdirect.com
    gmpartsdirect.com will probably look the part up for you if you email them, they are good about that.
  6. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    I would just look in summit for the braded steel fuel line set that they sell from pump to carb. What kind of carb do you have. I just did a TBI swap and have the line but it has been modified to fit a Holley. If nothing else you can buy some straight fuel line and a bender and make your own. I see you are in Houston also; what part?
    Charles
