Fuel line replace...How?
Discussion in 'The Garage' started by socal chevy, Apr 7, 2005.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    ...The Fuel line that goes from the fuel pump too the Carb...
    How do you get that thing out? The threading on the fitting for the carb is leaking, and I want to replace it. But I cant get it out...its stuck. Is there a way to get it out? Or do I have to take alot of other crap out to get it free? Thanks!
  2. dyeager535
    26,977
    First off use a good flare wrench. I start at the fuel pump....typically at the carb they like to twist as you try and undo it...gives you a bit of play if the fuel pump end is loose.
    1" open end on the carb nut, and use the flare on the fuel line. Tap the flare wrench with a hammer to hopefully break the nut free from the line.
