fuel line tpi
Discussion in 'The Garage' started by PeteH, May 4, 2006.
  1. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    so i took out the wrong fuel line on my truck while doing the tpi swap.
    it had the return line and the feed line to the carb.
    i took out the old feed line (instead of the return line)
    can i use the old carb return line(1/4) as the tpi return line? i know most people use their old feed line(5/16) as the return but i'm dumb and took it out. theres only about 3-5lbs of pressure in the return line right.
    or could i get rid of the canister purge and use its 5/16 line? but if i do that wont the gases build up in the tank ...how do i vent it?
    or could i even keep the canister purge and swap lines...1/4 goes to canister purge and 5/16 goes to return line.
    one again..i fubbared.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    to be safe you should just run new line for the return line, when i did mine i bought 25 feet of 3/8 from summit for $20, it was plenty to do both the feed and return line that way i did not have to worry about the old rusty line
  3. PeteH
    Mar 26, 2003
    498
    San Jose
    i already did the ss feed line 3/8 with little amounts of the ss braided line. i even finished the return line... but i was looking at it and thinking to myself..thats not 5/16.. so i took my micrometer to it and sure enough it was 1/4 tube. then after a few unpleasent words i went inside and cried to my brotherns.
    it was a pain in the arse to bend it all, especially to get underneath all the brackets(engine an tranny mounts) when i made new feed line. it got to a point where i had to bend it after some of it was already mounted because there was no way to slide it in. rrrg
    so i figured why not just use the existing for return. but i then took out the wrong line.
    i really dont want to bend new lines but its looking like i'm going to have to.. unless theres anymore suggestions.
  4. PeteH
    Mar 26, 2003
    498
    San Jose
    bumpity bump bump
  5. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Get a bendin'!
    Its really not all that bad of a job, just see if you can't buy / rent a tube straightener, makes bending the lines a lot easier...
  6. PeteH
    Mar 26, 2003
    498
    San Jose
    yea i guess i'm gonna have to start bending..
    ..i have a bender and ive done quite a few cars/trucks before. ...i just dont like doing em. I just figured i could use my 1/4 line as return but i guess not.:doah:
    ...wait a minute..a tube strightener?dont have one of those..
  7. Russell
    Jun 23, 2000
    7,923
    333
    Its not a requirement, just makes it a bit easier to bend. But seeing as you've done it before, it shouldn't be that bad. Only a few very minor bends to make on these frame rails :)
