fuel lines for an 87 tbi blazer - hard lines from the frame
Discussion in 'Parts & Trucks Wanted' started by jjlaughner, Oct 16, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    just like it says, I'm looking for replacement lines for my 87 TBI K5 fuel to and return lines.
    Also could use good brake hard lines.
    let me know what you have /forums/images/graemlins/1zhelp.gif
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the brake lines are simple to make, double flaring kit are inexpensive and so is small tubing cutter, i make lines all the time here, theres little tricks here and there like if you need to reuse a threaded fitting because it is an odd size but if you cant get the fitting off the old tubing then take a drill bit same size as the line, IE. 3/16" or 1/4" and drill the old tubing out of the fitting, this also cleans them up so fitting will turn good on the new line. /forums/images/graemlins/laugh.gif tubing bender is inexpensive too, and most of the time you dont relaly need one, usually i bend lines over large screwdriver handles or hammer handles, etc. unless need to be real tight bend,.
    goodluck
  3. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    I got an 86 frame out here, I know it's got the fuel lines on it, I'll look for the brake lines too.Not sure what it would package up in, but if interested let me know.
    Conoverbandit
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    goodluck
    I actually I have the tubing bender I just dont want to hunt down the different sizes and try to cut them to length. I'm trying to get the plow truck rolling for it snows /forums/images/graemlins/thumb.gif
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
