fuel lines
Discussion in 'The Garage' started by 85 Jimmy, Sep 8, 2006.
  1. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    i'm still trying to get everything together for my TPI swap and when i think i'm wbout done i always think of something else that i need to do it...
    anyway, when i swap the fi in i'm also putting in a new baffled tank and putting the fuel pump in the tank... my question is how much fuel line will i need to run all the way to the front and back??? and what line should i use? i have a 66 mustang and when i replaced the fuel line in that i just bought a 25' roll of aluminum fuel line, should i get that and bend it myself again? or should i just get some braided stainless line?
  2. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    with TPI having such high fuel pressures, I would plumb with all new steel or aluminum line. If you really want to plumb with hose, make sure it is rated for high pressures (should say it's FI hose). The aluminum fuel line will be much cheaper than a comparable length of FI hose.
  3. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    if stock send / return line system. just swap out the carb low pressure rubber hoses for efi rated hose.
    then use the return line as your return line. it only is bypass pressure. so free flow is all it needs.
    if your stock line is rusty then change it with new.
    if you only have a send line system then just use that line for return. then run a new hard line for send and use efi hose to make flex conections.
    then making line and useing hose . dont forget to make a small half flare to help hold the hose from poping off the hard line.
