fuel lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Dan, Dec 18, 2002.
  1. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    here's the problem.needed to redo heads.put them back on when igot to the tbi the feul lines didnt match up.well i ended up stipping one i was wondering what to do .is it possible to cut lines and run rubber or something else.any suggestions. /forums/images/graemlins/blush.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/blush.gif
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Thats what the guy before me done to my new project truck. I dont like it though! It does hold up to the pressure for the EFI but I'm thinking of rerunning new hard lines and bend them myself in the spring. Another more expensive idea is Areoquip flexable lines (thats another idea I'm thinking about, it would be MUCH easier but more expensive). good luck, Jeremiah
  3. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    thanks im going to try it .im really low budget at the moment ill see if it works i guess.then fix it right when get the money .don't know how much fuel line would cost .just need to get this thing running.thanks
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Make sure you get Fuel Injection (rated ~50psi I have seen 300PSI) type line. As opposed to carb type fuel line (rated at less than 20 psi).
    I made this mistake a long time ago.... NOT FUN! /forums/images/graemlins/angryfire.gif
  5. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    thanks hope it works.
