Fuel Pressure Gauge location?
Discussion in 'The Garage' started by BigCountryx, Mar 25, 2006.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I bought an actron Fuel Pressure guage with the schrader valve adapter. My question is where have you guys installed this and did you leave the adapter in place? The instructions say to install it by the fuel filter, then remove it from the line when done. I thought I had read where people had installed the on the inlet to the TB and left it there for years w/o problem. Whats the concensus? Installing it by the TB would be more convenient it seems.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
  3. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    I've got one, that's what I'm asking about. Where should I install it and can I leave it inline? The directions say to put it by the fuel filter, but I would like to put it under the hood.
  4. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Well if you already have one you can install it inline wit hthe TB. They prolly say to install it by the FF and remove it to cover their ass from law suits in case it leaks all over a hot engine, starts a fire, and burns up the whole world. If you install it permanatly get a chrome or metal cap (the same kind you use on a tire air stem) for the Schrader valve to seal it up unless you plan on leaving the guage hooked up to it. But I dont recomend leaving the guage on cuz its just one more thing that can go wrong.Engine fires are a real bummer.
  5. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Here's where I put mine:D
    http://coloradok5.com/photos/showphoto.php?photo=11736&cat=500
    I only wanted it for troubleshooting and tuning when converting to EFI, so I kept it under the hood. I'm running a Holley 4brl TBI and there are 1/8"NPT refference ports on both the high pressure and low pressure side of the fuel pressure regulator, so I just tapped into that.
  6. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
