Fuel Priming system, easy DIY
Discussion in '1982-Present GM Diesel' started by savagek5diesel, May 10, 2006.
  1. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    Well a while back i had asked if anybody knew if running an outboard boat motors fuel primer ball inline with our diesel's fuel line would work. Well i did it and sure enough... when my fuel lift pump was broken, i was still able to prime the fuel all the way up to the injectors and run the truck for about 15 minutes before it died again. here's a picture of my setup.
    just below the ball pump, i put an anti-siphon barb to keep the fuel from falling all the way back down to the tank...( because i have a leak in my IP) this works great guys. so give it a shot.​
  2. dallassnowman
    dallassnowman 1/2 ton status
    Sep 14, 2003
    339
    Forney, Texas
    I tried that about 6 months ago after a filter change ....it didnt work.
  3. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    i just might try that
  4. savagek5diesel
    Nov 20, 2003
    310
    Redding California
    works for me
    i've been running this setup for almost a month now and still no problems, so i don't know what you did different dallas, but thats too bad your setup didn't work how you planned.
