Fuel pump: Electric or mechanical?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer79, Jul 9, 2001.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I'm a few days away from finally swapping my 454 into my Blazer. The previous owner didn't include a fuel pump, so I ask: Should I order an electric fuel pump, or a mechanical one? Pros & cons of each, please.
    If I use an electric one, do I need to remove the rod that used to move the mechanical pump?
    I'd like to go with the mechanical because it's easier to install. But if you tell me some good reasons, I'll go with an electric.
    Thank you for your comments.
    <font color=purple>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Stick with the mechanical unless you are pumping out some serious horses!
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Really?? I would've said go aftermarket external electric, for ease of swapping and one less accessory running/dragging on the motor. That's just for those reasons, though, mechanical pump reasons may beat that out.
    Ratch
    <A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A>
    **K5 - What more is there to life?**
  4. dyeager535
    26,980
    Mechanical.
    Ease of install. (don't have to add extra wiring, I don't know about you, but the least wiring, the better)
    If you have to replace it, you know that an aftermarket mech. pump will work, no matter the maker.
    Can keep the steel lines (VERY important if you ask me)
    Puts out more than enough fuel for stock application
    Stock mech. pumps last 100k
    No annoying noises like an electric.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Read what Dyeager said below your post... He posts some good resons to stay mechanical. I have an Electric now.. What a pain.. If I could have gone Mechanical, i would have in a heart beat!!! But my 350 block does not have a mechanical pump provision(1991 block)...
