Fuel Pump Grounding
Discussion in 'The Garage' started by Hossbaby50, Nov 7, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am installing my fuel system for my TPI conversion. I installed my pump last night. It is an electric inline pump from MSD. I am wondering if grounding it straight to the frame will be fine or if I should run a lead straight to the battery for the ground? I was thinking that the frame should be fine.
    A second thought. Does the negative lead need to be run from the fuel pump relay? I was under the impression that only the positive lead needs to be run from there. Is this correct? Thanks
    Harley
  2. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    The neg lead on my stock pump goes right to the frame. I would think the aftermarket pump would also be fine this way. As for the relay, I would think it's grounded to the body which is grounded to the frame. I never heard of any isolated grounds on vehicles before. Just my .02 cents.
  3. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Yes the frame is fine and if memory serves (foggy at best) no you don't ground the relay. Remember though it's been quite a while since I wired a relay. Someone else I am sure has done this lately. Good luck to ya.
    Allan
