Fuel Pump location 1987 K5
Discussion in 'The Garage' started by Metrodps, Oct 8, 2007.
  1. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,607
    80
    earth
    I need to know where it is in relation to the rear lip of sheet metal and the inner sides of the floor. I am going to cut the floor to change mine. The fuel tank has 31 gl in it. I had planed on doing this just not right now.
    I found out mine did crap on me Friday! :mad:
  2. 4X4HIGH
    Dec 14, 2001
    22,006
    39
    Pleasanton, CA.
    Not sure how far forward from the rear but it is centered between the sides. You can probably look from the side and see close enough how far forward you'll need to cut.
  3. dyeager535
    26,533
    74
    It will take time, but if you don't want to cut, in my experience, you CAN siphon it out of the tank at the fuel filter connection. It's slower of course, but if you put a good pump in there, you should have another 100,000 miles before you have to deal with it again.
  4. Metrodps
    Jan 4, 2006
    9,607
    80
    earth
    I know some one here did it! I have a pic but no name.
  5. dsmd58
    dsmd58 1/2 ton status
    Sep 18, 2005
    624
    Mine crapped out yesterday...thank god the previous owner cut the floor. my cut looked exactly as the one above.
  6. Metrodps
    Jan 4, 2006
    9,607
    80
    earth
    Dude I need measurements!!!!!!!!!!!!!!!!!!!
    PLEASE and thank you.
  7. BLIDVL
    BLIDVL 1/2 ton status Premium Member
    Mar 18, 2007
    382
    Northern Va.
    Don't know if this will help[ or not, I cut an access door on my 89 Suburban and it was roughly 24" from the lip to the center of the sending unit and centered between the bedsides. Looking at my Blazer it measures to be about the same , I cut about a 16 x 16 hole and it was just about perfect. Kind of seems like it wouldn't be because the suburban looks like it has more overhand in the rear but I measured it as best as I could and they appear to be the same.
  8. BLIDVL
    Mar 18, 2007
    382
    Northern Va.
    Oh btw, I cut mine with the tank out, I'm sure you wouldn't do this but it will help some to loosen the tank straps a little and stuff something in between the lines and the floor just in case, ie piece of wood or something, hope this helps.
  9. Metrodps
    Jan 4, 2006
    9,607
    80
    earth
    Truck is fixed just waiting for a ride to go get it. Pics if not to dark other wise I will post them tomorrow. Thanks all!
  10. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    I know you already got it fixed but 1tonmudder has his floor cut for that reason.
    I just swapped mine out a couple months ago but we dropped the tank. It stays on empty really so it was pretty easy.
  11. Metrodps
    Jan 4, 2006
    9,607
    80
    earth
    OK all here is the measurement for future reference. Standing at rear lookin in.
    1. Go min 11 inches up from the tailpan lip.
    2. The side post at tail on the inside measure from each side
    28 inches along the lip then mark at the 11 inch line
    3. The top of opening should be a min 8 inches.
    I hope this helps!
