Fuel pump: mechanical or electric
Discussion in 'The Garage' started by big pappa b, Mar 20, 2005.
What type fuel pump do you have: mechanical or electric
  1. Stock mechanical
    14 vote(s)
    46.7%
  2. aftermarket electric pump
    10 vote(s)
    33.3%
  3. I don't have a fuel pump. I'm a web wheeler only...and naked
    6 vote(s)
    20.0%
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Whatcha got? If you went electric, what kind do you have?
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Unsure of the part number but mine is one from Edelbrock. Came with the FI Setup and pumps out around 50 or so PSI. Got to looking for similar ones on the net so I could carry a trail spare and they are pushing a few hundred bucks......
  3. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I say stick with mechanical, to me an electrical pump is just something else that can go wrong when you're in the middle of nowhere.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I voted electric but that is because I have FI. If I had a carb still I would be running a mechanical pump. They are to cheap and to easy to replace to worry about messing with the electrical.
    Harley
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    On the 72 K5 with the 454, I ran both. It would vapor lock every now and then, just hit the switch for the electric fuel pump and no more vapor lock. :D Also had 3 gas tanks, damn I miss that truck.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Electric with a regulator that has a return line.
  7. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Ok all you people voting for the electric pumps....what kind are you using??
  8. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I'm running a Carter. I can't give you the model # because it's been installed on the truck for about 10 years now, with no troubles at all. I DO know that it's a 2-stage (pull/push) pump and it needs to be mounted as close to the tank as possible......
  9. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    also might be wrong but if your running efi you have to get an electric b/c mech. wouldnt pump out enough psi
  10. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    I did not vote because you left out stock electric pump. When I got the 454 in we left the original stock in tank electric fuel pump in. It does not have any problems feeding the carbed BBC:D
  11. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Guess for now I'll leave the mech one there. I will eventually be getting rid of the carb and changing to a FI setup. Guess I was just looking for another excuse to buy something new to go along with the new fuel cell ;)
  12. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I couldn't find the factory electrical choice in the poll. I converted to tbi and used a stock elec/sender from a 87 K10 saddle tank in my K5. I was going to buy the one that goes in the fuel rail. Think it was from a camaro (napa# 5001) about $140.
  13. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    My truck currently has a no-name low pressure pump. Its noisy and the wife has wanted it to go away for awhile. I just picked up a red holley to replace it. I should have it on the truck in April sometime - I still have a motor to finish assembling and other assorted projects.
