fuel pump problem
Discussion in 'The Garage' started by sapper, Nov 17, 2003.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    The truck died on me driving home the other night, and trying to figure out what was wrong i noticed that the fuel pump was not coming on, yesterday i drop the tank pull the assembly out of it and replace to pump and sock filter, put it all back in and still no power to the pump, is there any kind of relay or something else electrical that i need to look for? All of the fuses are good and the truck acts like it wants to run just no fuel getting into the engine /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    what year truck is it? in general if it has an electric in tank pump/sender, you have a fuel pump relay, the one in our s-blazer is underhood on the drivers side in the battery junction box, if that helps, fuel pump relays are usually the more rectangular looking kind as well..pop the hood, swap a couple relays and see what happens, also check the fuses..im thinking maybe a 15 amp, but check them all
  3. sapper
    Jul 11, 2001
    3,052
    NoVa
    its a 89, any idea where these relays are mounted? TIA
  4. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    It should be on the firewall, just above the A/C and heater hoses go thru.
