FUEL PUMP QUESTION
Discussion in 'The Garage' started by Frank, Sep 6, 2004.
  1. Frank
    Frank Registered Member
    Oct 2, 2001
    16
    When I turn on the ignition I hear the fuel pump hum for a few seconds then the humming stops.
    Is this the normal fuel pump function or is it suppose to have a steady humming sound while the ignition switch is on?
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    the fuel pump humming is the sound of the pump building up pressure in the lines, it shuts off when the desired preassure is reached., it will turn back on while the engine is running but it is much harder to hear
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    hummmm??? /forums/images/graemlins/screwy.gif
