Fuel Pump Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Mar 19, 2001.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Does anyone know if the 86 K5 has electronic fuel pump??? I am trying to install a 454, and I need to know if I need to look into a pressure regulator. I am installing a 750cfm 4150 Holley for the 454, and if the truck has a elec. pump, I'm sure I will have to tone it down some so I don't make the Holley unhappy :-(
    Suggestions???? Thanks all!
  2. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    Looking at the Specs it says that fuel injection started in 87. Going from this info you should have a mechanical fuel pump on the engine. Make sure the 454 has a mechanical pump or you could go with an aftermarket electric fuel pump that puts out about 6PSI pressure. If you want run a higher volume get a 12PSI and run a fuel pressure regulator. To much pressure will unseat the needle valve in the float bowl and cause a flooding situation.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I helped a guy replace his...actually I replaced it while HE watched...on an '86 C20 and it was electric.
    90K5
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I was never lucky enough to see the factory installed 350... I bought the truck minus drivetrain. I spose that I could look for a harness at the tank, right? Could the VIN tell me anything do you think?
  5. pr1aw
    Sep 17, 2000
    144
    San Diego CA
    That was my next suggestion, look at the tank for wires going to it. If so, then you might be lucky because the orginal had a carb on it and the electric fuel pump will be of the proper pressure. I would still hook up a fuel pressure tester to see how much pressure though.
