Fuel Pump Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GrandNat86, Apr 6, 2001.
  1. GrandNat86
    GrandNat86 Registered Member
    Mar 27, 2001
    8
    Sayville, Long Island, NY
    I was wondering how long the fuel pump should run on my '87 K5 with a 350 TBI. After I shut of the motor, the pump continues to run for up to 10 seconds. I thought thisa seemed unusually long. Thanks for any info.
    Rob Andersen
    '87 K5 Silverado
    '86 Buick Grand National
  2. 87JIMMY
    87JIMMY Registered Member
    30
    MN
    I don't remember mine running after I shut down at all. If nobody else on the board knows, I can check tonight after work and repost.
    Scott 87JIMMY
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Totally normal..............my converted TPI 406 does it for a few seconds, and my engine builder/TPI conversion guru mentioned that is totally normal.
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Not really a problem, but I have seen them just keep running... this can fry the pump pretty quick. Usually it is fixed by throwing in a cheap fuel pump relay. Has worked twice for me now and the other was shorting in the wires.
    1987 Chevy K5 Blazer- 350 TBI
  5. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    you should wire the pump to your acc. so when you turn the key on or off the pump turns on or off immediatly cuz like CaptCrunch said if it runs to long it'll fry so if you think about it 10 sec after a while start to add up. thats just my opinion
    <A target="_blank" HREF=http://jimjim.coloradok5.com>http://jimjim.coloradok5.com</A> [​IMG]
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The fuel pump runs all the time that the engine is on. With how many hours it is run I don't think 10sec. would make any difference. What kills fuel pumps is runing them dry (i.e. Run out of gas). They are cooled by the fuel and overheat when you run out of gas. I have multiple friends that have destroyed them this way (Some more than once. You think they would learn after the 1st).
    '71 Blazer CST with alot of rust
