Fuel pump question?
Discussion in 'The Garage' started by hidesertwheelin, Apr 2, 2005.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    Can I mount a in-line fule pump on my 90 Sub as a back up to the factory in tank one? Or should I just install a pick up in the tank and use only a in line pump?
  2. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    you can mount is as a backup, but it has to allow free flow when not turned on
  3. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    you can do both but if the inline pump is a higher psi than the intank you need to remove the intank pump for the higher psi.
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Some fuel pumps can't have pressure being fed into them. You'd have to find out if that pump can have a pressure being applied to it.
  5. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    If i were you i would either get a pump with the same psi as the intank or take the intank out and buy 2 inline pumps... if 1 fails you can replace it in 15 minutes... I'm not sure if the stock pump will allow flow if it fails.
