Fuel pump relay and fuse location on 91 K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 5.0THIS, Sep 10, 2002.
  1. 5.0THIS
    5.0THIS Registered Member
    Apr 3, 2002
    13
    Louisville, CO
    Recently my 91 K5 wouldnt start, so the first thing I did was spray some starting fluid down into the TB, and it fired right off, so I know it's fuel related. I cant hear the pump running in the tank, but before I go dropping the tank I want to check the electrical first. I have not been able to locate the fuel pump fuse and relay, could anyone help me out here on their locations, thanks very much
    Andy
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The fuel pump relay is mounted on the firewall, just to the passenger side of the engine. It's oval shaped when looking from the top of it. But if you can hear the pump kicking on when you turn on the key, then the relay is working. /forums/images/icons/frown.gif So check first for fuel pressure. Also check to make sure that the fuses for the injectors are good. They're located in the fusebox under the dash.
  3. 5.0THIS
    Apr 3, 2002
    13
    Louisville, CO
    I see the relay.... is there any way to test it before simply replacing it? Also, I cannot locate the fuel injector fuse in the fuse block just above and to the left of the brake pedal? any thoughts?
  4. 5.0THIS
    Apr 3, 2002
    13
    Louisville, CO
    Ok... I found the fuel pump fuse, over mounted on the heater core near the passenger front fender, a 5A fuse, which was ok. the relay is pretty cheap, I suppose I'll give that a try first. if that isnt it, I have heard these vehicles have a fuel pump inertia swtich, or an oil pressure switch, that might also shut the pump down. Anbody?
  5. Sandhills Blazer
    Sandhills Blazer Registered Member
    Nov 6, 2001
    45
    South Carolina
    Before you go out and buy the relay. Have a friend get in and attempt to start the vehicle and while he does that take a big rubber mallet and knock the you know what out of the bottom of the fuel tank. If the pumps bad it will start up about 90% of the time. If it does not start it could still be the pump. No start, then take a chance on the relay. I just went through this on my 91 K5. It's not too bad. Just takes time.
  6. dyeager535
    26,976
    As I recall my wiring, they use a relay, as well as an oil pressure switch. I *think* if the oil pressure raises (such as extended cranking) even if the relay has failed, it will still start. So if thats true, which I think it is, then if the oil pressure switch is "seeing" no oil pressure, the pump won't work.
    Relay itself should be fairly easy to test, when one of the small wires gets 12V, (such as key to "run") the switch closes(? proper term?) and 12V "flows through" the relay. One big wire is the 12V "in", and one is 12V "out", basically one big wire is 12V battery, and one is 12V to whatever accessory is being run.
    At least thats my understanding of it.
    You do know there is a fuel pump terminal on the ALDL connector, right?
  7. 5.0THIS
    Apr 3, 2002
    13
    Louisville, CO
    Well, it isnt the relay, it's not the fuse, so it's either the oil pressure switch or the fuel pump. Guess it's time to start dropping the tank and do the pump, any tips anybody? /forums/images/icons/smirk.gif
