Fuel pump relay for carb electric pump
Discussion in 'The Garage' started by sled_dog, Jul 7, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I am looking at throwing this Painless setup in the S10 to power my Holley Blue pump. How do I know if this relay is good enough for my pump? Should I just trust that since its Painless it will be fine?
  2. dyeager535
    26,976
    Just me, but I'd go to the wrecking yard and take a relay from an 80's/90's GM vehicle. Cut the wiring plug out with it, and wire it up yourself.
    That description says "weatherproof", not waterproof, if you were thinking along those lines as compared to a stock relay.
    Shouldn't cost you anywhere near $33, and the wiring is work you'll have to do anyways. My opinion. :)
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Most any Bosch type relay will handle the load. Try waytekwire.com
