fuel pump relay location 88 k5
Discussion in 'The Garage' started by dynoram, Sep 10, 2005.
  1. dynoram
    dynoram Registered Member
    May 27, 2004
    13
    where is the son of a gun? fuel pump works sometimes so im figuring relay cant really hear a click either. Where is the the relay located?
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    It is just to the left of center on the firewall right next to the heater/ac suit case. There is usually fuel pump relay mounted on a bracket with an empty space right next to it. It is a common GM problem for the relay to go bad so i bought an extra and placed it in the empty spcae so if and when mine ever goes bad i just swap the wiring to the next relay and keep going. :thumb:
  3. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    a tip...
    Many vehicles use the same relays on the A/C,or other accesories as the fuel pump..you can swap them around in an emergency if need be-could prevent a long walk home!..I often swap them around to see if its the relay thats bad,then if it works,I know I have to go buy a new one.. :crazy:
  4. dynoram
    May 27, 2004
    13
    Thanks fellas ran out of daylight figure it out in the AM. :D
