Fuel pump relay - what to use
Discussion in 'The Garage' started by TX Mudder, Nov 24, 2003.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Subject says it all. WHat should I be looking for? Holleys ays a universal fuel pump relay kit, but it sells for $67 /forums/images/graemlins/shocked.gif
    Shouldn't I be able to find a suitable relay cheaper at the parts store?
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Yes you can find relays cheap rated at like 30 amps(local auto parts store). They will have wiring instructions with it. You also need wire(at the least 12 guage for the fuel pump), female connectors, FUSE!, and a switch to activate the relay(or wire to the ignition for when the key is on).
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    A fusable link is a safer option over blade or glass tube fuses.
    A 16g fusable link should be used for 12g wire.
    Fusable links should not be used in cab though.When they go there is a fair bit of smoke along with it.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    A really cheap solution would be to grab a fuel pump relay and wiring harness from an EFI GM car or truck at the junkyard. /forums/images/graemlins/cool.gif
