Fuel pump replacement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rampage, Jun 17, 2002.
  1. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    I think it's time to replace my electric fuel pump. What else should be replaced besides the pump? And where did you get your parts from? I'm thinking of cutting out an access hole in the floor with a die grinder and just letting a shop do the work since I don't like the thought of working near gas. Any thoughts?
  2. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Cut a hole in the floor for access. Layne Oberto (K5BLT4FUN) did this using my On Board Air in Disney, OK. PM him and he may remember the exact mesurements. Great for "full tank" pump replacements.
  3. ds350
    ds350 1/2 ton status
    Jan 26, 2001
    190
    Bay Area
    rampage,
    The main problem with the orginal tanks is that the tank baffel comes loose. Make sure that it is still attached securely before reassembly.
    Danny
