Fuel pump seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazinzuk, Jun 24, 2006.
  1. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I have a blazer gas tank that is fuel injected and it is leaking from the top. It is where the fuel pump and sender and everything go in, its leaking from the locking ring. Any suggestions, want to be armed with some knowledge before I try to fix it.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    There is a big O-ring under the sender/pick-up unit. Not sure if they can be bought in your local parts store but i would check with them first.
  3. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    IIRC you can get the new o-ring seal when you bye a sock and a fuel pump... i believe it was 40 bones or so.. not bad, because if your gunna drop the tank you might as well change the pump and sock while you are at it
    LUKE
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I checked at our parts store and found out the O-ring you need is a dealer itiem and does not come with a fuel pump or sock.
  5. dyeager535
    26,982
    191
    The Delco pump I purchased came with a sock and the o-ring, FWIW.
    Might check acdelco.com and see if they list what comes with your particular pump.
    Also, if you have a local place that sells o-rings, (more an industrial supplier, not a hardware store) they MIGHT have what you need.
  6. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    Well the tank is easy to get to now so its no big deal I still havent' even worked on this trying to to get mine running
  7. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I bought a new tank, got a free o-ring. Bought a new pump, got a free o-ring, bought a new sock, and thought "I better get a new o-ring" before opening the others and got a new o-ring. Now I have 2-spares!
